Recent Solutions
Using the find command Linux Terminal
Here is the syntax for using the find command Linux terminal. The following commands are great to have in your back pocket when looking for specific files or directories. How to find a file from the root directory and check the entire system: find / -name filename.ext See directory structure without...
Update to the Latest Version of GIMP
Here are instructions on how to Update to the latest version of GIMP. This is vital to make sure you get the newest and best features for GIMP. The old versions of gimp that come bundled with Ubuntu 18 and prior aren't nearly as good as Gimp 2.10+. Start by...
BigDaddyLinux Interview
I had a great time chatting with Rocco from BDL and loved his interview style. I didn't realize we talked for an hour and half, but had an absolute blast and will definitely jump in on some more of his live streams. Here is the interview: https://www.youtube.com/watch?v=3J-knijf2iY If you get...
Grub Rescue | Repairing your Bootloader
Lets go over Grub Rescue and repairing your bootloader. This is a very misunderstood topic and by learn basic syntax you will be able to repair your GRUB very easily. Here are 4 methods of doing a GRUB Rescue. Repairing from a GRUB > Prompt Find your Hard drivels Output...
WordPress on Google Cloud Platform
I am going over hosting WordPress on Google Cloud Platform in this article. This is a step by step guide on how to set up and host a WordPress website using a fresh installation. Step 1: Fresh VM console.cloud.google.com(Note: Be sure and install gcloud https://cloud.google.com/sdk/docs/downloads-apt-get)Setup Project and VM (micro)sudo apt...
Aptitude Explained
In this article I am going over the aptitude command and explaining all of the commands and usage that goes with its usage. Install Aptitude Run the following command to install aptitude and task select: sudo apt install aptitude tasksel Why Aptitude? Aptitude provides greater dependency resolution and wildcard installations....
Article 13 – European Union and YouTube
This is about Article 13 and Why it is actually great for YouTube as a company but will cause more censorship across the European Union. The main debate is holding the sharing platform liable for any damages sustained. YouTube is angling to say they are protecting copyright holders due to...
