Remove Asterisk from Linux server (ubuntu/centos/debian/rhel)
The following removal instructions go over how to completely remove Asterisk from your Linux Instance. REMOVE AND REINSTALL INSTRUCTIONS Here is how to remove Asterisk from a Linux server and reinstall from source. Pre-requirements: Download source, configure, make menuselect, and make. All done with root (sudo su) Example: sudo su ###ENTER...
GFI Archiver resource usage
Does your GFI Archiver resource usage SQL process ballon over 8GB? If so, the following procedure will reduce usage by about half and fix many performance issues. 1. Stop all MailArchiver and SQL services 2. Create a backup of ..MailArchiverStoreDataproduct.config 3. Edit product.config and add the following key within the...
CT Summation Summary Import Settings
When importing .dat or .csv files into CT Summation v3.0 you will find that the field separators and quote characters can change when using various vendors. Here are the 2 sets of characters that I've found most vendors use. Use the following CT Summation summary import settings and you will be...
Removing or Adding 9 to Dial out on VeriFone VX510
Using the following steps to add or remove a 9 when using the VeriFone VX510 to process credit cards. Step-by-Step Instructions First go into Quick Setup (6 on pad) Password is 1 Alpha Alpha 66831 Select Phone Edit to add or remove 9 and then exit Done! Now run a couple...
