GFI Archiver resource usage
Does your GFI Archiver resource usage SQL process ballon over 8GB? If so, the following procedure will reduce usage by about half and fix many performance issues. 1. Stop all MailArchiver and SQL services 2. Create a backup of ..MailArchiverStoreDataproduct.config 3. Edit product.config and add the following key within the...
Configuring SQL Authentication
Configuring SQL Authentication can be tricky at times, and this is a great article that goes over the two types of authentication in SQL. I find some programs interface better with direct SQL authentication when Windows Authentication fails for any reason. Note: This article is taken from http://kb.gfi.com/articles/SkyNet_Article/How-to-configure-SQL-Server-2005-2008-to-accept-SQL-Authentication and all credit goes to...
Archiving and Reducing Exchange Mailboxes and Stores (Part 2)
You have analyzed your current exchange store and deciding to buy a 3rd party solution so your users can maintain the large amount of emails they are accustomed to and retain all emails for legal/business purposes, and here are the options. Buy the Barracuda Message Archiver ( website link: http://www.barracudanetworks.com/ns/products/archiver-overview.php)...
