Force Application to use one network connection
There is an application called ForceBindIP that allows you to bind certain applications to network connections. It doesn’t work for all applications, but most of them. It is also a bit glitchy in Vista and 7.
Download ForceBindIP
Write down your IP Addresses. I use a wired and wireless connection.
-Run -> cmd
-ipconfig
Modify your Application shortcut’s target window
-Add forcebindip ipaddress in front of “C:applicationpathexecutable.exe”
Enjoy!
