CT Summation Summary Import Settings
When importing .dat or .csv files into CT Summation v3.0 you will find that the field separators and quote characters can change when using various vendors. Here are the 2 sets of characters that I’ve found most vendors use. Use the following CT Summation summary import settings and you will be able to use any load file. Should you run into any problems, correct the inconsistencies in the load file using Notepad++.
Summation Default
Field Seperator ASCII 44 ,
Quote Character ASCII 34 ”
3rd Party Vendor Load files
Field Sperator ASCII 20 ¶
Quote Character ASCII 254 ■
Leave any Questions and Comments below and I will get back to you. I regularly publish on YouTube, Steemit, and christitus.com so if you’d like to see more videos and articles click the subscribe button in the top right.
